PCIE hard ip issue, when i try to integrate two PCIE hard IP's ,than synthesis is being failed.( family Cyclone V , gx )
Adding one more query is it possible to assign only IO's for PCIE HARD IP and do Analysis to generate the ".pin" file for the board team.
When we try the above step we are getting the compilation error as below
Error (177035): The input pin PCI_EP0_REFCLK_P assigned to HSSI Pin_W8 has no fanout.
Error (177035): The input pin PCI_EP0_REFCLK_N assigned to HSSI Pin_W7 has no fanout.
Error (177035): The input pin PCI_EP0_RX_P[0] assigned to HSSI Pin_AG2 has no fanout.
Error (177035): The input pin PCI_EP0_RX_P[1] assigned to HSSI Pin_AE2 has no fanout.
Error (177035): The input pin PCI_EP0_RX_N[0] assigned to HSSI Pin_AG1 has no fanout.
Error (177035): The input pin PCI_EP0_RX_N[1] assigned to HSSI Pin_AE1 has no fanout.
Error (177035): The input pin PCI_EP1_REFCLK_P assigned to HSSI Pin_N7 has no fanout.
Error (177035): The input pin PCI_EP1_REFCLK_N assigned to HSSI Pin_P8 has no fanout.
Error (177035): The input pin PCI_EP1_RX_P[0] assigned to HSSI Pin_R2 has no fanout.
Error (177035): The input pin PCI_EP1_RX_P[1] assigned to HSSI Pin_N2 has no fanout.
Error (177035): The input pin PCI_EP1_RX_N[0] assigned to HSSI Pin_R1 has no fanout.
Error (177035): The input pin PCI_EP1_RX_N[1] assigned to HSSI Pin_N1 has no fanout.
Error (11802): Can't fit design in device. Modify your design to reduce resources, or choose a larger device. The Intel FPGA Knowledge Database contains many articles with specific details on how to resolve this error. Visit the Knowledge Database at https://www.altera.com/support/support-resources/knowledge-base/search.html and search for this specific error message number.
Error: Quartus Prime I/O Assignment Analysis was unsuccessful. 13 errors, 13 warnings
Error: Peak virtual memory: 5625 megabytes
Error: Processing ended: Tue May 07 17:54:45 2019
Error: Elapsed time: 00:00:16
Error: Total CPU time (on all processors): 00:00:16
