15 years agoPC <-> S530Dev. Bd. Reg R/W interface?
Hi - so I just got my first Altera Development kit (S-IV GX S530). My "hello world" project starts with a tiny user-designed design (i.e. RTL code) that I download to the board that consists of so...
15 years ago --- Quote Start --- What I'm finding is a disconnect between Qsys and Quartus. I mean, after I have a project complete in Qsys, how do I get it into an FPGA? Do I set up the project, pinout, etc, manually, or is there some Qsys-> Quartus tool that helps. I'd be surprised if there wasn't, but I'm not finding it. I appear to have to generate project file, sdc file, etc, from scratch. Really? --- Quote End --- Qsys generates a component. There's nothing special about that component, it just happens to be automatically generated. An FPGA design consists of a pinout, SDC file, and HDL files; one or more of which may be Qsys generated components. I typically generate top-level designs using; * a generic top-level design entity (VHDL) containing all pins on the board * a pin assignments Tcl script that sets up all the I/O * SDC files * A design-specific Tcl script that ties it all together (runs the Quartus build) The top-level entity/architecture file is copied-and-pasted into each design, and then the architecture body is edited to connect the design-specific top-level design into the generic top-level design (which always has the same pin names). For example, lets say I have a Qsys component called qsys_test that I want to simply drop into the FPGA. I would take my Stratix IV GX development kit top-level design s4gxdk.vhd and inside that file instantiate u1 as the qsys_test component, then connect up whatever pins I need, eg., connect a qsys_test bus called pio(7 downto 0) to the LEDs or a GPIO bus in the top-level generic design. So, there is a little manual work required, but its similar between designs, so most of it can use common scripts (to minimize copying files), or a common template that can be copied-and-pasted, followed by minor editing. Cheers, Dave
