15 years agoPC <-> S530Dev. Bd. Reg R/W interface?
Hi - so I just got my first Altera Development kit (S-IV GX S530). My "hello world" project starts with a tiny user-designed design (i.e. RTL code) that I download to the board that consists of so...
15 years ago --- Quote Start --- So I'm wondering how much wasted effort there is in starting with ISSP as it will get me up and running quicker..... --- Quote End --- The System Console approach is not too bad. Rather than doing a lot of reading, start with 'doing'. Create a Quartus project, select the Stratix IV part, start Qsys, create a new Qsys design, add the JTAG Avalon-MM master, the RAM, and the PIO component. Put the LED at address 0, and the RAM at say address 0x1000. Instantiate the system in a top-level VHDL or Verilog design. Synthesize it. Assuming your PIO has 8-bits, go into the pin assignments editor and assign these pins to the LEDs on the board. Re-synthesize the design; check the .pin file to confirm that only the LED pins are used and the others are reserved (tri-stated). Start system console, eg., in Quartus v11.0 Tools->Transceiver Toolkit, and then type 'source {<windows path to>/jtag_cmds.tcl}', where the curly braces pass the path to the 'source' command as a Tcl list. Look at the jtag_cmds.tcl file to see the procedures in there (the .tcl file is in the .zip attachment). Now type 'jtag_read_32 0' to read the LEDs, 'jtag_write_32 0 0x55' to write to them, or 'jtag_read_32 0x1000' and 'jtag_write_32 0x1000 0x12345678' to access the RAM. There are also LED Tcl procedures defined, eg. led_read and led_write 0x55. That should give you enough of an incentive to go this route :) Cheers, Dave
