On my fpga, 'or' is 'and' and vice versa
Hello, I recently bought an ALTERA Cyclone IV EP4CE6 FPGA and tried to create the first project. When key_1 and key_2 were clamped, led_1 should have been lit.
But led_1 is lit when key_1 is clamped when key_2 is not pressed.
- FvM
Hi, I presume the FPGA is fine. But you don't consider that switches and LEDs of your board are apparently implementing inverted logic. Closing the switch applies '0' to the input, LED is lighted with output '0'. - SyafieqS
Let me know if there is any update from previous reply.
- SyafieqS
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
