8 years agoOn-board usb blaster configuration files for MAX 10 10M50 Evaluation Kit
Dear all,
We want to reuse deign files of the MAX 10 FPGA 10M50 Evaluation Kit (6XX-44364R): https://www.altera.com/products/boards_and_kits/dev-kits/altera/kit-max-10m50-evaluation.html I need to know how to get XAX II configuration files for on-board usb blaster II. Where can I get that configuration image or logic source for EPM1270_M256FBGA? What if I replace EPM1270 with EPM240 due to cost? At that time, is the proper configuration file available? Thank you in advance. jo.2 Replies
You can't get it - not legally anyway. It's a protected Altera design, not available for use on customer boards.
Cheers, Alex - Altera_Forum
Do you really need the USB Blaster "on Board" or would a JTAG I/F and external USB Blaster work as well... If you need the functionality on board there is meanwhile some module including the functions to be soldered on PCB avaliable from Trenz-Electronic via Arrow.com...
