rsing108
6 years agoNot able to generate bitstream of design using devcloud
i am trying to generate bitstream for my oneapi code. I have verified it using the fpga emulator. The report generated is also fine with around a maximum of 50% resource utilization in RAM and DSPs. ...
rsing108
6 years agoThanks for your reply LLand1.
The time out seems to be the problem. I explicitly defined the timeout using "walltime" to a maximum of 24 hours. But it seems my design is even taking more than that. So, it timed out after 24 hours again. But I guess the issue is as you mentioned because of time out only. Is there any way I can launch a session for more than 24 hours?
