rsing108
6 years agoNot able to generate bitstream of design using devcloud
i am trying to generate bitstream for my oneapi code. I have verified it using the fpga emulator. The report generated is also fine with around a maximum of 50% resource utilization in RAM and DSPs. ...
Lawrence_L_Intel
6 years agoIf you can try this in batch mode we can find out if the session is timing out (default is 6 hours). See this https://github.com/intel/FPGA-Devcloud/tree/master/main/Devcloud_Access_Instructions#54-submitting-batch-jobs and then look at the Quickstart guide: https://github.com/intel/FPGA-Devcloud/tree/master/main/QuickStartGuides/OneAPI_Program_PAC_Quickstart/Arria%2010 . ;let us know if batch mode works. Thanks, Larry
