VHou0
7 years agoNIOS2 bidirectional IO port setting
Set an 8-bit bidirectional IO port as output mode in NIOS2 code, but only 4 bits (bit 0, 1 ,4 ,5)can output correctly, and the other 4 bits hold out state 0.
- Ahmed_H_Intel1
Can you please explain more? what is your issue?
- Ahmed_H_Intel1
please check the top level connection first. you can share with us the top level connection and the assigned pins for these LEDs.
- VHou0
Thanks you .I removed signaltap from the project, it works correctly.
