TRAN_HIEU_007
5 years agoNew port Ethernet use Cyclone10GX KIT error.
I add a new port Ethernet 1G in Cyclone10GX KIT. But I received this error.:
Error(14566): The Fitter cannot place 1 periphery component(s) due to conflicts with existing constraints (1 LVDS_CHANNEL(...
EngWei_O_Intel
5 years agoHi
Which is actual issue you are facing in your design? Would you mind to share a sample design that is causing the issue? It looks like your design is having assignment issue between LVDS and IOPLL. But we have to look into the design for detail understanding.
Eng Wei
TRAN_HIEU_007
5 years agoWhen I use another connection port to connect with IP core TSE, the above error is encountered in the fitter (if I edit in pin planer). But when I edit the port in the Assignments editor The above error does not appear. But project simple_socket_sever not working and stop when I try to debug config pcs. I used the project in the sample. I can not attach files. I don't know why I got this error.
InterNiche Portable TCP/IP, v3.1
Copyright 1996-2008 by InterNiche Technologies. All rights reserved.
altera_eth_tse_init 0
prep_tse_mac 0
Can't read the MAC address from your board. We will assign you
a MAC address.
Please enter your 9-digit serial number. This is printed on a
label under your Nios dev. board. The first 3 digits of the
label are ASJ and the serial number follows this.
-->Created "Inet main" task (Prio: 2)
Created "clock tick" task (Prio: 3)
123456789
123456789
Your Ethernet MAC address is 00:07:ed:ff:cd:15
prepped 1 interface, initializing...
tse_mac_init 0
List of PHY profiles supported (Total profiles = 5)...
Profile No. 0 :
PHY Name : Marvell 88E1111
PHY OUI : 0x005043
PHY Model Num. : 0x0c
PHY Rev. Num. : 0x02
Status Register : 0x11
Speed Bit : 14
Duplex Bit : 13
Link Bit : 10
Profile No. 1 :
PHY Name : Marvell Quad PHY 88E1145
PHY OUI : 0x005043
PHY Model Num. : 0x0d
Speed Bit : 14
Duplex Bit : 13
Link Bit : 10
Profile No. 2 :
PHY Name : National DP83865
PHY OUI : 0x080017
PHY Model Num. : 0x07
PHY Rev. Num. : 0x0a
Speed Bit : 3
Duplex Bit : 1
Link Bit : 2
Profile No. 3 :
PHY Name : National DP83848C
PHY OUI : 0x080017
PHY Model Num. : 0x09
PHY Rev. Num. : 0x00
Status Register : 0x00
Speed Bit : 0
Duplex Bit : 0
Link Bit : 0
Profile No. 4 :
PHY Name : Intel PEF7071
PHY OUI : 0x355969
PHY Model Num. : 0x00
PHY Rev. Num. : 0x01
Speed Bit : 0
Duplex Bit : 0
Link Bit : 0
INFO : TSE MAC 0 found at address 0x10020000
INFO : Multi Channel = No
INFO : MDIO Shared = No
INFO : MAC Type = 10/100/1000 Ethernet MAC
INFO : PCS Enable = Yes
INFO : PCS SGMII Enable = Yes
INFO : MAC Address = 0x10020000
INFO : MAC Device = tse_mac_device[0]
INFO : PHY Marvell 88E1111 found at PHY address 0x00 of MAC Group[0]
INFO : PHY OUI = 0x005043
INFO : PHY Model Number = 0x0c
INFO : PHY Revision Number = 0x2
INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0]
INFO : PHY[0.0] - Advertisement of 1000 Base-T Full Duplex set to 1
INFO : PHY[0.0] - Advertisement of 1000 Base-T Half Duplex set to 1
INFO : PHY[0.0] - Advertisement of 100 Base-T4 set to 0
INFO : PHY[0.0] - Advertisement of 100 Base-TX Full Duplex set to 1
INFO : PHY[0.0] - Advertisement of 100 Base-TX Half Duplex set to 1
INFO : PHY[0.0] - Advertisement of 10 Base-TX Full Duplex set to 1
INFO : PHY[0.0] - Advertisement of 10 Base-TX Half Duplex set to 1
INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link...
INFO : PHY[0.0] - Auto-Negotiation PASSED
-- Program stop here.
