16 years agoNeed help creating a simple 32bit counter
I'm trying to learn VHDL so I thought I'd try converting the "my_first_fpga" example from verilog to VHDL (how complicated can adding one to a number be?), three hours later, lots of googling and sea...
16 years ago --- Quote Start --- Thanks Tricky, that got me up and running :) Does verilog operate the same way in relation to instruction flow and signal vs variable? Also is there a good source for these idiosyncrasies in the language? In an unrelated question every time I recompile I need to goto Tools -> Simulator Tool -> Generate Functional Simulation Netlist to run a simulation, is there a way to automatically generate the netlist or am I doing something wrong? --- Quote End --- I do not know anything about verilog, though the words blocking and non-blocking assignments has been used before to equate signals and variables in VHDL from time to time. for the 2nd point you're simulating a post-P&R netlist, which will be slow (but will function as it would on real hardware). In modelsim you can simulate your VHDL text files directly with no synthesis required. You will need to create a testbench to stimulate all of the inputs (like generating a clock) but thats quite straight forward. To generate a clock in a VHDL testbench you can just use the line:
signal clock : std_logic := '0';
clk <= not clk after 10 ns; --will give 50MHz clock
and then just connect the clock to the clk port on your counter.
