16 years agoNeed help creating a simple 32bit counter
I'm trying to learn VHDL so I thought I'd try converting the "my_first_fpga" example from verilog to VHDL (how complicated can adding one to a number be?), three hours later, lots of googling and sea...
16 years ago --- Quote Start --- You should show complete library and signal/variable definition. Generally, this code is supposed to work. But possibly, you found a way to thwart it.
if CLK'EVENT AND CLK = '1' then
counter := counter + 1;
Q <= counter ;
end if; --- Quote End --- Like I said, it thwarts the synthesisor because there it sees no point in registering counter, because it registers Q instead. Because counter never read's back from Q, counter is always assumed to be 0. The best way to fix it and make it synethsise is swap the 2 statement, or do this instead: if CLK'EVENT AND CLK = '1' then
counter := Q;
Q <= counter ;
end if;
