DNguy4
7 years agoMemory IP for PAC card
When I use the Intel Arria10 development board, I can generate the memory example design and select the Arria10 development board, then copy the memory IP to my design and use it. However, I don’t se...
Deshi_Intel
7 years agoHI,
Are you referring to the DDR4 memory on Intel A10 GX FPGA PAC card ?
Intel PAC card comes with fixed DDR4 configuration on the board. PAC card is designed for usage model where user installed the acceleration stack software that will auto instantiate DDR4 memory + other transceiver channel as whole solution package nicely for user.
There is no need and reason for user to manually configure DDR4 IP anymore. Therefore, there is no DDR4 IP example design like what Intel provided on other Arria 10 development kit board.
dlim
- DNguy47 years ago
Dlim,
Yes, I am referring to the DDR4 memory on Intel A10 FX FPGA PAC card. I installed the acceleration stack SW but i still cannot find the memory IP. I see some other IPs such as DDR4_mm_bridge IP, Altera 10G Ethernet MAC IP, PLL IP, CRC32 IP... but I cannot find the memory IP. Any idea?
- DNguy47 years ago
I mean Intel A10 GX FPGA PAC card.
