Zahkriin
4 years agoMax1000 Remote System Upgrade via SPI
I have a Max1000 development board and would like to perform a remote system upgrade with it. I have programmed an SPI interface to send the required data. (Here not necessarily SPI must b...
Chudik
2 years agoHow interesting. The topic is Remote System Upgrade via SPI
However everybody switched to UART... May I make offtopic question and ask about discrete RSU via SPI (or I2C)?
From the very starting point - which IP block should I use for it?
The part I'm using is 10M08 with Verilog. I can translate from VHDL to Verilog, but original Verilog code is preferable.
There is a page with example for RSU via I2C but it does not help. Opening .par file shows only top file for 10M50 used as a I2C host. Structure of the project and used IP blocks are invisible
Besides the description of the project and how to run written for Quartus 16 and for a template it suggests to use an evaluation board that does not exist anymore.
