Max1000 Remote System Upgrade via SPI
Here is an example of RSU with UART (with 57600 baud console connection) on same device. I think you can find your answers in it.
Thanks for the example project. I found an answer to my question, however I don't quite understand why? You write in line 854 that the maximum address is 13ffh (79871). In the Platform Designer it says under Flash Memory that the largest address is 0x4dfff (319487 or 8*79871 - 1). Why do you divide the addresses by 8?
Furthermore I don't understand your page_erase_addr in line 740. Of course you take 19 bits, because there is so much space in the register. But why do you start counting up in the middle?
- jozephka994 years ago
Contributor
1. As in the UFM user guide at (https://www.intel.com/content/www/us/en/docs/programmable/683180/18-0/sector-address.html), you have to convert the sector addresses to the avalon mm addresses. This process done by dividing 4 not 8 (2 bit shifting).
2. Page erase operation at below the line ~740 is just UFM erase. Actually you can add here CFM sectors as well but I done CFM sectors erasing in sector erase mode. As you can see in UFM user guide (https://www.intel.com/content/www/us/en/docs/programmable/683180/18-0/ufm-and-cfm-array-size.html) 10M08 devices has 8+8= 16 pages in UFM sections. If you look at the flash ip, you can see that UFM sectors are between 0 and 0x07fff. It is normal sector addressing. It means approximately 0 - 0x2000 in avalon addressing and that is equal to 0-8192 bits. So we have 16 pages total, then one page's address is 8192/16=512 in avalon addressing. For this reason I increase the UFM page erase addresses by 512 for each page of UFM. I hope it doesn't confusing. In fact it is hard to understand that addressing and documentations about it is very poor.
- Zahkriin4 years ago
Now I finally understand how the addressing works. Thank you for your quick and very helpful answers.
