RLee42
7 years ago"Match PLL Compensation Clock" assignment doesn't work
Hi, When I used Quartus to compile for a cyclone V device I got an warning, which was just the one in the link below. I followed the Workaround/Fix part of the link to try to remove the warning b...
RLee42
7 years agoHi lvan,
Thank you for your time.
I did choose "normal" when I generated PLL and I thought Quartus should know the way to compensate, however, I still got a warning as below:
Warning (177007): PLL(s) placed in location FRACTIONALPLL_X0_Y1_N0 do not have a PLL clock to compensate specified - the Fitter will attempt to compensate all PLL clocks.
Then I assumed that there might be some extra options for compensation which I missed. That's why I said "When I generated PLL I didn't see the options for compensation".
Thank you.
Ross
