"Match PLL Compensation Clock" assignment doesn't work
Hi RLee42!
First of all, there are different compensation modes in Altera PLL IP core, so it's strange that you didn't see them. You can read about them here : https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/altera_pll.pdf - Operation modes.
You can choose them from the GUI - you already made a selection (normal).
About your questions -
- In that case fitter will compensate all PLL clocks like this : " Normal mode—the PLL feedback path source is a global or regional clock network, minimizing clock delay from the input clock pin to the core registers through global or regional clock network."
- The workaround should help - I successfully eliminated problem in my own project.
Hope that helps.
Ivan
- RLee427 years ago
Hi lvan,
Thank you for your time.
I did choose "normal" when I generated PLL and I thought Quartus should know the way to compensate, however, I still got a warning as below:
Warning (177007): PLL(s) placed in location FRACTIONALPLL_X0_Y1_N0 do not have a PLL clock to compensate specified - the Fitter will attempt to compensate all PLL clocks.
Then I assumed that there might be some extra options for compensation which I missed. That's why I said "When I generated PLL I didn't see the options for compensation".
Thank you.
Ross
- RLee427 years ago
Hi lvan,
Thank you and I tried it too but failed.
I'm not sure if you can see the message I replied GNg.
Yes, you are right that I could ignore it. I just have interest on why the warning is there that I may have something that can be improved.
I don't know whether it matters that I couldn't edit the PLL IP in the project.
It was also strange that I generated the PLL in Quartus Lite 18.1 and tried editing it in Quartus Lite 18.1 too, which was also met by some other people .
I might try to generate it again if no better choice.
Thank you.
Ross
- IDeyn7 years ago
Contributor
Hi RLee42!
I can see the message of GNg, and first of all, please try to do what he suggests - you need to find from netlist "~outclk_wire[0]".
As about problems with editing of PLL in 18.1 Quartus it is another problem, you can explain the problem in more details.
Ivan
