SPere43
6 years agoMakeFile for Include openCV
Hey guys!
I'm try compile a c++ project, and i include libraries for openCV.
Now i need use a makefile, im try edit a makefile that came with the vector_add example.
But i have error's and i dont can compile.
You can give me help please?
# Copyright (C) 2013-2018 Altera Corporation, San Jose, California, USA. All rights reserved. # Permission is hereby granted, free of charge, to any person obtaining a copy of this # software and associated documentation files (the "Software"), to deal in the Software # without restriction, including without limitation the rights to use, copy, modify, merge, # publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to # whom the Software is furnished to do so, subject to the following conditions: # The above copyright notice and this permission notice shall be included in all copies or # substantial portions of the Software. # # THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, # EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES # OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND # NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT # HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, # WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING # FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR # OTHER DEALINGS IN THE SOFTWARE. # # This agreement shall be governed in all respects by the laws of the State of California and # by the laws of the United States of America. # This is a GNU Makefile. # You must configure INTELFPGAOCLSDKROOT to point the root directory of the Intel(R) FPGA SDK for OpenCL(TM) # software installation. # See http://www.altera.com/literature/hb/opencl-sdk/aocl_getting_started.pdf # for more information on installing and configuring the Intel(R) FPGA SDK for OpenCL(TM). ifeq ($(VERBOSE),1) ECHO := else ECHO := @ endif # Where is the Intel(R) FPGA SDK for OpenCL(TM) software? ifeq ($(wildcard $(INTELFPGAOCLSDKROOT)),) $(error Set INTELFPGAOCLSDKROOT to the root directory of the Intel(R) FPGA SDK for OpenCL(TM) software installation) endif ifeq ($(wildcard $(INTELFPGAOCLSDKROOT)/host/include/CL/opencl.h),) $(error Set INTELFPGAOCLSDKROOT to the root directory of the Intel(R) FPGA SDK for OpenCL(TM) software installation.) endif # OpenCL compile and link flags. AOCL_COMPILE_CONFIG := $(shell aocl compile-config --arm) AOCL_LINK_CONFIG := $(shell aocl link-config --arm) # Compilation flags ifeq ($(DEBUG),1) CXXFLAGS += -g else CXXFLAGS += -O2 endif # Compiler. ARM cross-compiler. CXX := arm-linux-gnueabihf-g++ OCV_INCLUDES = -I$(OPENCL4_INCLUDE) OCV_LIBDIRS = -L$(OPENCL4_LIB) OCV_LIBS = -lopencv_core440 -lopencv_highgui440 # Target TARGET := host TARGET_DIR := bin # Directories INC_DIRS := ../common/inc LIB_DIRS := # Files INCS := $(wildcard ) SRCS := $(wildcard host/src/*.cpp ../common/src/AOCLUtils/*.cpp) LIBS := rt pthread # Make it all! all : $(TARGET_DIR)/$(TARGET) #$(OCV_LIBS) $(OPENCL4_INCLUDE) $(OPENCL4_LIB) # Host executable target. $(TARGET_DIR)/$(TARGET) : Makefile $(SRCS) $(INCS) $(TARGET_DIR) $(ECHO)$(CXX) $(CPPFLAGS) $(CXXFLAGS) -fPIC $(foreach D,$(INC_DIRS),-I$D) \ $(AOCL_COMPILE_CONFIG) $(SRCS) $(AOCL_LINK_CONFIG) \ $(foreach D,$(LIB_DIRS),-L$D) \ $(foreach L,$(LIBS),-l$L) \ -o $(TARGET_DIR)/$(TARGET) -o $(TARGET_DIR) : $(ECHO)mkdir $(TARGET_DIR) # Standard make targets clean : $(ECHO)rm -f $(TARGET_DIR)/$(TARGET) .PHONY : all clean
1 Reply
- AnilErinch_A_Intel
Please check the below link
https://rocketboards.org/foswiki/Projects/OpenCVPort
and let us know whether this is helpful.
Also since this is showing undefined reference , you can check whether all the library files are included properly.
Thanks and Regards
Anil
