FMorf
6 years agoJESD204B - IP - Multiframe
hi, I have an arria 10 Soc development board and an AD9680. I only use one converter. I don't understand the parameter K. I thought I need them for more converters on a line. But with the IP set I c...
Nathan_R_Intel
Contributor
6 years agoHie Fabian,
What do you mean by signal with 1GHz. Are you referring to a 2Gbps signal. Please clarify?
Also can you calrify what is meant by 1000 measurement results?
Basically for users the main information needed to be be calculated in Sysref frequency.
To calculate this, you just need LMF, operation data rate and K.
Table 21 in the above documents shows the calculation.
Nathan
