FMorf
6 years agoJESD204B - IP - Multiframe
hi, I have an arria 10 Soc development board and an AD9680. I only use one converter. I don't understand the parameter K. I thought I need them for more converters on a line. But with the IP set I c...
FMorf
6 years agoHi Nathan,
thank for your answer. I read this data sheet, too, but I don’t understand this parameter.
For example: I sample a signal with 1 GHz. I use two lanes and my N’ is 16. I have a converter and I get a transmission frequency of 10 GHz.
So, in every 1 µs I get 1000 measurement results. So, what exactly is my multiframe now?
It can’t be 1000 because it is way too much because you can only set max. 32.
I need minimum 10 – so which effect does it have, when I increase the value?
Thank you so much for your help in advance.
Fabian
