BLeLu
7 years agoIs there a reference design of the displayport IP Intel running on A10GX development kit board and using the TX DP interface on the board ?
- Deshi_Intel
hi, you can refer to the Arria 10 TX only display port reference design in below link https://fpgacloud.intel.com/devstore/platform/18.1.0/Pro/intel-arria-10-displayport-tx-only-design/ Thanks. Regards, dlim - BLeLu
Thanks for this answer.
But This design uses the Bitec FMC daughter card to transmit the video output.
We target to use the on-board (J5) DP interface, is it possible with the same reference design ?
- Deshi_Intel
Hi Blelu, Sorry, the reference design is targeted with Bitec FMC daughter card only. You will need to modify the design yourself if you plan to use on board DP interface. Thanks. Regards, dlim
