Is it possible to use DDR3 without configuring it from the QSYS hardprocessor? I want to use DDR3 for the boot up of the HPS. What should be the steps i need to follow. Thanks.
Hello HPB,
Thanks for your reply.
it helped me allot.
now i have our own development board with DDR3 (MT41J128M16JT-125:K) and SoC (5CSEBA5U23I7N) on it.
i am now able to run the baremetal on chip memory by following this tutorial.
https://www.intel.com/content/www/us/en/programmable/documentation/lro1424280108409.html
Now i get the following error if i want to use "Create a New Scatter File to Locate the Bare Metal Application in the SDRAM"
ERROR(CMD16-TAD274-NAL22):
! Failed to load "bare metal-hello-world-01.axf"
! Failed to write 4,896 bytes to address S:0x02000000 while writing block of 4,096 bytes to address S:0x02000000
! General error on memory or register access.
Is there any method to debug why i get this error?
in my memory view of DS-5 i cant see the DDR3 memroy (my program runs in the endless loop)
Is there any possibility to move forward.
thanks.
Good to know that you are able to make the progress.!
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_bm.pdf
page 37
refer to "Create a New Scatter File to Locate the Bare Metal Application in the SDRAM " section
There are some similar errors mentioned and solution is mentioned. I think that should help you to proceed.
With Regards,
HPB
