Internal ESD protection of Arria V.
Hi Bruce,
please refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/arria-v/av_5v2.pdf page 155. There is a optional clampind diode shown. This diode is recommend for
"If the input signal is 3.0 V or 3.3 V, Altera recommends that you use a clamping diode on the I/O pins. Use the on-chip clamping diode for the Arria V GX, GT, SX, and ST devices, and an external clamping diode for the Arria V GZ devices."
Where to find the clamping voltage of this diode? Where to find max. voltage and current for clamping event of this diode? Are the values mentioned by you the max. ratings for clamping event?
Its very import for us to find out because of Maximum Allowed Overshoot During Transitions for Arria V Devices in https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/arria-v/av_51002.pdf page 6.
Depending of AC input voltage the Overshoot event could be taken in account with the optional clamping diode mentioned above.
Many thanks in advance.
Kind regards,
Sven
