BChiw
7 years agoIntel EMIF FPGA IP DTS / DTB error.
Hello, Need help for this DTS/DTB generation error. We are using this link as the base design: https://rocketboards.org/foswiki/Projects/A10AVCVPCIeRootPortWithMSI Then we added the FPGA DDR4 int...
BoonT_Intel
7 years agolooks like the system not recognize any driver for emif. But seem like you only need to access the FPGA EMIF from HPS as a flat memory, maybe you can try to modify the DTS to flat memory as below. See if you still can access the address from HPS.
// emif_0_ecc_core: unknown@0x100000040 {
// compatible = "unknown,unknown-16.1";
// reg = <0x00000001 0x00000040 0x40000000>;
// clocks = <&emif_0_arch 0>;
// }; //end unknown@0x100000040 (emif_0_ecc_core)
memory {
device_type = "memory";
reg = <0xc0000000 0x20000000>;
