BChiw
7 years agoIntel EMIF FPGA IP DTS / DTB error.
Hello, Need help for this DTS/DTB generation error. We are using this link as the base design: https://rocketboards.org/foswiki/Projects/A10AVCVPCIeRootPortWithMSI Then we added the FPGA DDR4 int...
BoonT_Intel
7 years agoHi Sir,
For the design, it already consist of the DDR4 which is HPS DDR4. So, I believe the emif_0 that you added is the FPGA EMIF.
Is this FPGA EMIF will used by your HPS system? If it is not use, then you can just delete those component emif_0* from the DTS file.
