Intel EMIF FPGA IP DTS / DTB error.
Thanks for the link. Yes, also followed the Rocketboards procedure.
Following the suggested link above gave the same results as before.
Please see screen output below.
--barny
> embedded_command_shell.sh
Intel FPGA Embedded Command Shell
Version 17.1 [Build 590]
> sopc2dts -i ghrd_10as066n2.sopcinfo -o ghrd_10as066n2.dts \
-b ghrd_10as066n2_board_info.xml \
-b hps_a10_common_board_info.xml \
-b hps_a10_devkit_board_info.xml \
--bridge-removal all --clocks
Component emif_0 of class altera_emif is unknown
Component emif_0_arch of class altera_emif_arch_nf is unknown
Component emif_0_ecc_core of class altera_emif_ecc is unknown
Component emif_0_col_if of class altera_ip_col_if is unknown
Component emif_0_col_if_colmaster of class alt_mem_if_jtag_master is unknown
Component emif_0_cal_slave_component of class altera_emif_cal_slave_nf is unknown
> dtc -I dts -O dtb -o socfpga_arria10_socdk_sdmmc.dtb ghrd_10as066n2.dts
ERROR (phandle_references): Reference to non-existent node or label "emif_0_arch"
ERROR: Input tree has errors, aborting (use -f to force output)
