I am using MAX10 FPGA in my design and i am making JTAGEN pin as NC, because i dont want to use sharing. is it ok? is there any problem?
Hi Arvinda,
No,
Intel recommend to pull-up JTAGEN pin to a weak 10-kΩ pull-up.
If the JTAG pin sharing is not enabled, the JTAGEN pin is a regular I/O pin and JTAG pins function as JTAG dedicated pins.
To use JTAG pin as dedicated pin, tie the JTAGEN pin to a weak 10-kΩ pull-up
Reference,
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/max-10/pcg-01018.pdf
Anand
Hi Anand
thanks for your reply
weak pull-up means just need to enable the weak pull-up option for that particular pin right ?
- AnandRaj_S_Intel7 years ago
HI Arvinda,
Yes, jtagen pin has an internal 25-kΩ pull up. but still we required external 10-kΩ pull-up.
Anand
- AKuma1507 years ago
Hi Anand
thanks for your help
Aravind
