KLind7
7 years agoI am unable to get the bsp-editor to make the preloader for the embedded SOC in windows 10. The make file fails.
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/embedded/2018/unable-to-make-preloader-in-windows-10.html Here is the article that shows the erro...
EBERLAZARE_I_Intel
7 years agoHi,
The problem is with the Cygwin permission in Windows system. The directory for the fstabin is as you mentioned the ftsab file. The command is to fix the permission errors. Once the it has been added, it should fix the make file error.
If it is not, we recommend that you use Linux system for the time being.
Regarding the libpng12 library, we are aware of the issue and since the libpng12 is no longer available via the "apt-get method", download and install libpng12 from this link:
https://packages.ubuntu.com/xenial/amd64/libpng12-0/download
Regarding missing libraries information you can refer here:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/quartus_install.pdf#page=6
Regards.
