how to use N3000 as a plain NIC to send/receive packet
When I follow the instructions to update XL710 drivers, it shows 'Update not available' and 'Devices not found'. I paste the output at the beginning of the question.
Hi Max,
Thanks for the information. Most of your drivers seem to be in the latest version.
From Hardware sides
- Based on the information available in the readme notes for the Intel® Ethernet X722 drivers,
- the devices are based on the Intel Ethernet X710, XL710, X722,
- and XXV710 controllers may fail to load with a yellow bang error.
- This may be because the device is connected to a switch that is not advertising traffic class 0.
- Maybe you can try to disconnect the device from the switch or configure the switch to advertise TC0,
and restart your system.
If the hardware confirm no issue, you may try step below
- Appreciate if you get me the logs following, so that we can narrow down the issue
- https://cdrdv2.intel.com/v1/dl/getContent/332161?wapkw=Intel%C2%AE%20Ethernet%20NVM%20Update%20Tool:%20%22Quick%22%20Usage%20Guide%20for%20Linux
- Section 6.1 Troubleshooting Using Debug Logs
Please let me know if you need any further clarification,
looking forward to hear back from you
WeiChuan_C_Intel
- Wincent_Altera5 years ago
Hi Max,
Any update for the Debug logs ?
Let me know if you have any questions.
Looking forward to hear back from you.
Regards,WeiChuan_C_Intel
Hi Max
There is no reply from you.
I am setting this case to closed-pending,
This loop will be close after 5 days if still no reply
Hoping to hear back from you.Regards,
WeiChuan_C_Intel
