How to read data in FPGA out of external DDR3 SDRAM on an Terasic DE10-Nano
To enable FPGA2SDRAM Bridge, you can do it from the Preloader or U-boot:
>from U-Boot:
At the U-boot command prompt add:
“run bridge_enable_handoff”
*This command puts the HPS and SDRAM into a safe state before enabling all bridges after appropriate checks.
> Can someone help me or give me a code? (to read the DDR3 address space):
There is actually a sample code from Terasic website on you specific board, on Nios access DDR3, you will need an account when clicking the Download link.
Jump to CD-ROM > DE10-Nano CD-ROM (rev. C Hardware) > Download:
https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=205&No=1046&PartNo=4
Extract thenyou can find the project file example in > DE10-Nano_v.1.3.5_HWrevC_SystemCD\Demonstrations\SoC_FPGA\Nios_Access_DDR3
Feel free to ask if you have further questions.
Regards.
Thank you for your answer.
I have already seen the Nios_Access_DDR3 example.
My question is: Is there another way to access the addresses without DMA and NIOS? I would like to read the data only with VHDL / VERILOG code.
Regards.
- EBERLAZARE_I_Intel7 years ago
There might be other way to access the addresses, but there are none from Intel that have the sample code that represent the address access.
Except the example that I provided which is external which is the Nios Access DDR3 example.
You may find some useful examples here:
https://github.com/robertofem/CycloneVSoC-examples
Regards.
- JGros127 years ago
thanks for your quick reply.
What do you think about the DDR3_RTL example (TERASIC GHRD). Maybe I can use this as an startpoint for my application.
Yes, I would recommend the the example as it demonstrate the FPGA site to access the DDR3 at HPS.
From there you can understand how the f2h bridge interfaces, etc..
