How to make N3000 support jumbo frames?
I believe if you are in DPDK, you need to revert back to OPAE to set the MTU. See below link to revert back to OPAE.
The matter is that if I revert back to OPAE and set the MTU size again, the MTU of XL710 would be returned to the default value 1500 even though we set it to 9600 after bounding to vfio-pci driver in the mode of DPDK
- JonWay_altera5 years ago
How do you set the MTU of the XL710? What is the command?
- ahaa5 years ago
ls -la /sys/class/net
sudo ip link set dev enp61s0f0 mtu 9600
sudo ip link set dev enp61s0f1 mtu 9600
sudo ip link set dev enp64s0f0 mtu 9600
sudo ip link set dev enp64s0f1 mtu 9600
ip link show enp61s0f0
ip link show enp61s0f1
ip link show enp64s0f0
ip link show enp64s0f1
sudo fpgadiag -b 0b3f -m fpgamac --side=host --mtuthen bound to dpdk
- ahaa5 years ago
another problem is that I cannot check mtu size after bounding to dpdk
