8 years agoHow to load softare for dev. board demos
How are existing NIOS II demo projects loaded into Eclipse for running in NIOS II hardware? I am familiar with steps to creating new Eclipse projects for Quartus systems, but am having tr...
8 years ago --- Quote Start --- You should be able to open the 'workspace' directory for the existing project. This is typically the folder with the '.metadata' folder in it. Alex --- Quote End --- Hi, Alex, thanks. Yes, so i see a folder called software in NIOS designs. This is where the .metadata file is. I also see the main.c file and many others - i have tried opening main.c but do not think this is the way. --- Quote Start --- Alternatively, open a new workspace and 'import an existing project' into workspace. Then point at the folder containing the example project (typically with a '_app' & '_hw_platform' folders in) and import them. Cheers, Alex --- Quote End --- Regarding 'workspace' and 'import an existing project' , here are you referring to the Eclipse application or Quartus II/Quatrus host application? Thanks,
