how to link everything together?
- 5 years ago
Hi David,
Regarding the error message, I think this is due to different versions of the Intel Quartus Prime software that you are using and the version used to create the example. Some of the qsf settings in older version are not supported in the newer version.
For reference design, you may find in the link below. User Guides and Reference Designs > Reference design.
Besides the reference design, you may also generate some simple example designs using the IP parameter setting GUI.
KhaiY
Hi David,
KhaiY
Hi KhaiY
Even I have many years FPGA design experience, but relatively new to the Platform Designer. Thank you very much for the suggestion.
I followed your link and try to this link
https://www.intel.com/content/dam/altera-www/global/en_US/pdfs/literature/an/an708.pdf
in this document, there is a link
• Arria 10 Reference Design( https://www.alterawiki.com/wiki/Reference_Design:_Gen3x8_AVMM_DMA_with_external_DDR4_-_Arria_10)
To download the reference design and the design software
if I click the Arria 10 Reference design link, I will get this message.
"The requested URL was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request."
could you please give a valid link to the <<Arria 10 reference design>> referred in the an708 page 3.
if I can get a full example project which cab be compiled, it will be a very good start point for me to understand PCIe and memory controller.
David
