WKUAN
5 years agoHow to instaniate a SFL ip core in the design
I am using ARRIA10 with EPCQL1024, now the ARRIA10 is ok, the SOF can be configured into the FPGA, but when I configure the EPCQ1024 with JIC file, the configuration failed.
After read an...
YuanLi_S_Intel
5 years agoHi,
In signal tab tools, at JTAG Chain Configuration tab there, you may click the "device" to select the device available in the JTAG chain.
Meanwhile, for the error (12852), it seems like the USB Blaster that you are using is having issue. Can you try with another USB Blaster?
Bruce
- WKUAN5 years ago
Thanks Bruce,
The problem has been solved by replacing the USB Blaster with USB Blaster II cable.
KUANG Wu
