WKUAN
5 years agoHow to instaniate a SFL ip core in the design
I am using ARRIA10 with EPCQL1024, now the ARRIA10 is ok, the SOF can be configured into the FPGA, but when I configure the EPCQ1024 with JIC file, the configuration failed.
After read an...
YuanLi_S_Intel
5 years agoHi,
You dont need to instantiate SFL IP when you are programming JIC into FLASH using Quartus Programmer.
May i know what error you got during programming?
Bruce
- WKUAN5 years ago
Hi Bruce,
Thank you.
I am afraid the EPCQL1024 chip is damaged, because i can not configure the chip.
Now I have a new problem, the FPGA on my board is 10AX115N3F45E2, but when I scan chain in signaltap, the chip is 10AT115S1, so i can not debug the chip with signaltap. when i use programmer with the .sof file, it is ok to configure the chip 10AX115N3F45E2, and the code works, it is very confusing!
KUANG Wu
