DSchm28
7 years agoHow to initialize the DMA of the HPS?
Hi, I use an Cyclon V SoC FPGA (on an DE10-NANO). I would like the to use the integrated DMA Controller from HPS (no IP Core on Platform Designer) to write Data from my own buffer to the HPS2FPGA . ...
DSchm28
7 years agoThank you for your first answer. But I would like to copy data from Buffer on HPS to another/other buffer on HPS and the HPS has an DMA Controller - why should I use the FPGA DMA (speed is not so interesting)?
I have bind in the libs alt_dma.h and alt_dma_common into my main.c file. So every time when I uses fuktion from that libs (fokused alt_dma.h) I get linker error. Why doesn't work?
Thanks for your answer.
