NSook
6 years agoHow to get USB Blaster II under Programmer in Quartus Prime Lite?
I'm currently trying to set up the USB Blaster II for a Max 10 10M08 Evaluation Kit using Ubuntu ran on Virtualbox. On terminal, it says that the USB blaster is connected (using lsusb). I've also cre...
NSook
6 years agoThis is the output when I run dmesg -w. The first box indicates when the device is initially connected. The second box is the output when jtagconfig is run. Not sure why it is disconnecting.
