NSook
6 years agoHow to get USB Blaster II under Programmer in Quartus Prime Lite?
I'm currently trying to set up the USB Blaster II for a Max 10 10M08 Evaluation Kit using Ubuntu ran on Virtualbox. On terminal, it says that the USB blaster is connected (using lsusb). I've also cre...
NSook
6 years agoWhen I initially typed lsusb. it initially showed that the USB-Blaster was connected. When I typed jtagconfig, the blue light on the USB-Blaster turned off and then on again. Not sure if my USB-Blaster is working properly as I saw yesterday that after a while, it was disconnected from the USB bus. When I remove and reinsert the cable, it appears in the bus again.
