14 years agoHow to generate 30 PWM singals using MAX II starter kit
I want a dsp2812 to generate three PWM signals and a I/O singal and input them to the MAX II starter kit. and is there a neccessity to make a middle circuit between two kits? Also, I want to generat...
14 years agoI expect, that a simple cabel should be sufficient to connect both boards. 75 MHz will be probably good as a MAX II clock.
Without an idea about the complexity of multilevel algorithm, I can't determine if a MAX II can handle it. Code the algorithm in VHDL or Verilog and see how much resources it consumes. P.S.: For medium resource requirements a Terasic DE0 (Cyclone III, 16k LEs) or DE0-Nano (Cyclone IV, 22k LEs) should be suitable. Both have GPIO headers to connect 3.3V LVCMOS signals.
