AAjit2
7 years agoHow to convert Cyclone III Verilog files to Cyclone V?
I have an old FPGA board running on Cyclone III which has Verilog files but doesn't have any bdf, so it was difficult tracking the connections. Now I want to rewrite the programs for the new Cyclone ...
AnandRaj_S_Intel
7 years agoHi @AAjit2 ,
We can use our old design with little modification by considering below points.
- Check the IP used and regenerate it or generate new IP with respect to board resources/interface.
- Update the pin assignments.
Generate correct IP file , add it to project , integrate it top top-level file & compile the designa nd check
QIP file is Quartus IP file which is generated which generating IP from mega-wizard or IP catalog.
If possible share the project.
Anand
