How to continuously capture and log data from running design on DE1SoC using signal tap? Capture data for 1 hour and continuously save it to csv files ?
I would suggest that you make sure that the data can be acquired from signal tap.
Here is a guide that you can refer to:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/qts_qii53009.pdf
Also exporting captured data can be found on page 60 and the below link:
https://www.intel.com/content/www/us/en/programmable/quartushelp/current/index.htm#tafs/tafs/tcl_pkg_stp_ver_1.0_cmd_export_data_log.htm
Regards.
Can you attach the log files generated in two quartus_stp versions?
Also, was the data able to be exported successfully in .csv format?
Regards.
- RElna7 years ago
Hi Sure, How can I extract the logs ? Data has been exported to csv successfully only in version 18.0 but in version 15.1 it returns all don't cares. Best Regards, Rana - EBERLAZARE_I_Intel7 years ago
Probably you could share the screenshot of the exported don't care values and the logs that is displayed.
I suspect that the problem lies in the command "-data_log log_1" that is causing the issue, may I know where did you get the following script? From any sources/website?
For now I would suggest that you try triggering to make sure the data is captured correctly.
