jackhab
7 years agoHow to add pull-ups on DE10-nano GPIO
I'm trying to add weak pull-ups on JP7 GPIO1 of DE10-nano board. The board boots to Linux so as far as I understand FPGA image is loaded by Uboot from the rbf file on boot partition. There is a Def...
SreekumarR_G_Intel
7 years agoyou can make sure board revision and the file meant for the board are same .
Anyhow good news is you are able to boot it ; Now try modifying the working rbf design files and see any changes in the led.
I cant say what may be issue until fully compare the hardware and the software built for it .
Thank you ,
Sree
- jackhab7 years ago
My board revision is C0 and I verified the CD package I downloaded matches the HW revision.
What do you mean by " try modifying the working rbf design files"? If I try to modify Default Quartus project from the CD and create new RBF file it cannot be loaded by U-Boot.
