How to add pull-ups on DE10-nano GPIO
Ok...t , now i think i got the issue you facing ,
Actually you need to enable the compression option in the Quartus while converting the file into rbf .
Convert programming files -> click the sof -> properties-> click the compression check box
Can you try and let me know how it go ?
- jackhab7 years ago
I created passive parallel x16 RBF with compression.
The file size is 2.5MB vs original file's 3.3MB
FPGA programming OK: orange LED is on, green ones are blinking
But Linux boot still fails:
reading /extlinux/../zImage
5478000 bytes read in 375 ms (13.9 MiB/s)
append: root=/dev/mmcblk0p2 rootwait mem=0x3F000000 memmap=16M$0x3F000000 ttyS0,115200
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
SCRIPT FAILED: continuing...
reading /socfpga_cyclone5_de10_nano.dtb
29940 bytes read in 9 ms (3.2 MiB/s)
starting USB...
USB0: Core Release: 2.93a
dwc_otg_core_host_init: Timeout!
