jackhab
7 years agoHow to add pull-ups on DE10-nano GPIO
I'm trying to add weak pull-ups on JP7 GPIO1 of DE10-nano board. The board boots to Linux so as far as I understand FPGA image is loaded by Uboot from the rbf file on boot partition. There is a Def...
SreekumarR_G_Intel
7 years agoHello..Sure..so you are using the same file what given by the terasic and still you are getting the dtb file error right ?
or you modified anything there ?
Thank you ,
Sree
- jackhab7 years ago
I'd like to describe step-by-step what I did to make sure I worked with correct files.
I download DE10-Nano CD-ROM version 1.3.7 from www.terasic.com.tw
I extracted CD-ROM contents and opened Demonstrations\FPGA\Default\DE10_Nano_Default.qpf in Quartus 15.1 (the same version as appears in qpf file)
I compiled the project without any modifications
I converted the compiled SOF to Passive Parallel x16 RBF
I put the new RBF on the original SD card which came with DE10-nano in place of the original RBF
After reboot I got the error described above
