jackhab
7 years agoHow to add pull-ups on DE10-nano GPIO
I'm trying to add weak pull-ups on JP7 GPIO1 of DE10-nano board. The board boots to Linux so as far as I understand FPGA image is loaded by Uboot from the rbf file on boot partition. There is a Def...
SreekumarR_G_Intel
7 years agoAlso you saying when you boot up you are getting the device tree error ? can you use the image given by the terasic package , Kindly dont change anything and try to boot it
Thank you ,
Sree
jackhab
7 years agoI'm compiling with Quartus Prime 18.1. My SD card is the original one which came with DE10-nano and the only file I change is RBF.
By the way, if in case of Linux boot HPS configures FPGA shouldn't I use passive mode? This is what I understand from https://www.intel.com/content/www/us/en/programmable/support/support-resources/support-centers/devices/cfg-index/cfg-compare.html
