OLevy1
7 years agoHigh Speed Intel Reed Solomon Simulation Model Submodules are being generated in VHDL although i select Verilog Simulation Model
CheepinC_altera
7 years agoHi Oren,
Sorry for the delay. By looking at your previously attached error, sorry as I could not really tell what might be wrong with the compilation. It seems like some type with "extra characters after close-quote" message.
As a workaround, I would like to suggest you to start by configuring the IP to your target configuration, then use Generate -> Generate Example Design to generate the example design from the IP. Then try to compile the design using the msim_setup.tcl in Modelsim. Once you are able to compile and get the simulation running. Then you may try to customize from there to your target requirement.
Chee Pin
