SATC's avatar
SATC
6 years ago
Getting the outputs resulta from a file in real time
Hello, everyone.
How can I get the results of outputs and registers with the usb cable from a simulation running in real time? I'm trying the Signal Tap but I would like to know about others resources.
Thank you!
    • sstrell's avatar
      sstrell
      Note that In-system Sources & Probes is only "real-time" as far as how fast signal info is sent over the JTAG connection, so you're talking about kHz speeds. You're not going to be able to see high-speed signals toggling with ISSP.
      Signal Tap really is the main debug tool for looking at signals, through they are frozen at a moment in time.
      #iwork4intel
