Mohammed_Asif_S
5 years agoFPGA Current consumption
i am using 5M570ZT100C5N, i need to calculate the current consumption of this device, i am powering this device VCCINT 1.8V and VCCIO by 3.3V.
How to calculate the power consumption of this device ...
AminT_Intel
5 years agoHello Mohammed,
Thank you for using Intel® MAX® V FPGA.
You can calculate the power consumption of this device by using Early Power Estimator (EPE). You can find EPE of your device from this link
You can see the current consumption of each rail change as the I/O count for each module changes in under I/O tab. To view the current consumption per module, refer to the values in the "ICCIO" column in the EPE.
Hope this answer helps in your next design. Stay safe!
Thank you
- AminT_Intel5 years ago
I apologize that I put the wrong link. The correct link is here. Select your device and download it's EPE.
