Sushmita
5 years agoFFT IP option creates .qsys file instead of .qip
I am using quartus 18.1 version. i want to use FFT IP.
When I open the IP from IP catalog, i can see a platform designer option for FFT IP. i want to use the IP inside my design as a .qip file. Is there a option for that?
Can I use FFT IP inside my RTL as an instance?
1 Reply
- SyafieqS
Hi Susmita,
You can get the FFT qip after you generate the HDL in PD. Yes, you can use it inside your RTL as instance.
