NZhan1
6 years agoFatal error using Quartus Pro 19.2 on Win10 server
Hi
When compile A10 project, it will occur a fatal error before fit every time, using Quartus Pro 19.2 on Win10 server. What should we do?
the error is showed in picture.
there are lots of projects will have this error, including some project once worked well on Win10 PC.
the dll library can be found on the path showed in error message.
- KennyT_altera
Unfortunately, Quartus does not support windows10 server, it support only windows 10. You may check over here:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/download/os-support.html
Also, when you use windows 10 , you need to install
For Windows users you will need to download and install Windows Subsystem for Linux (WSL) for Windows 10.
- NZhan1
Hi Kenny Got it, Thanks! Regards, Nicole
