Failure Analysis request for field-failed Altera's FPGAs
Hi JP1,
PWR_p1v2 is refer to power pins.
From on the attachment ;
4-We perform measurements on the FPGA
RESULT=Fail
RMA_PWR_P1V2 ---->50 ohms
Golden
PWR_P1V2 ---->108 ohms
5-We carry out an inspection with the help of the thermal camera
Result = Fail
The MIFPGA shows a point with very high temperature
Based on the statement, we can see the failure symptoms is because of electrical Overstress (EOS).
EOS occurs when excess voltage or current flows in a circuit, which can cause further damage and causing major damage.
In this case, we can see the EOS caused the failure when the reading of the good and bad units is in huge difference. When the resistance is low, means that the current/voltage is high. The FPGA get unwanted current/voltage beyond its operating specs.
In order to avoid electrical damage, the device should always be handled in a static-free environment and all the input signals should remain within specified limits, as recommended in the PSG Data Book and associated application notes, at all times.
I hope this will help to clarify.
Wani
Hello Wani.
Thanks for the feedback. Let me check with our FA engineers to know their opinion.
Regards!
